Python Code Distribution (PyPI)
23/02/2024 --- Distributing Python Program --- Nathaniel SEYLER
This Tuto Techno is largely inspired by Loïc Gouarin Distribuer son Application Python
Before starting, clone the repository:
git clone git@gitlab.inria.fr:tutos-technos/python-pip-code-distribution.git
or
git clone https://gitlab.inria.fr/tutos-technos/python-pip-code-distribution.git
This presentation is also available in the wiki:
https://gitlab.inria.fr/tutos-technos/python-pip-code-distribution/-/wikis/home
It contains more details and exercises.
[TOC]
Introduction
  • The Python language is now widely used in research. Many libraries (applications) are developed in our laboratories and research teams using this language.
  • But are these developments given back to the community ? How much time and energy does it cost to make work available ? What are the benefits ?
  • In this Tuto Techno, we'll explain what a Python package is, how to organize your code to be ready for distributing.
Virtual environment
A python virtual environment is a small, easily reproducible and erasable space where you work in isolation.
Tools
  • venv : available since Python3.3 and is installed on your system at the same time as Python. It is a subset of virtualenv.
  • virtualenv: more flexibility than venv
  • pipenv: combines pip and virtualenv into one command
  • mamba: conda package manager but also manages virtual environment
Create and activate an environment
  • pipenv
    pipenv install
    pipenv shell
  • virtualenv
    virtualenv my_env
    source my_env/bin/activate
Declare your dependencies
These tools can install dependencies thanks to a requirements.txt file. This file can be shared by developer and can have the same development environment.
requirements.txt example:
numpy>1.20
matplotlib==3.7.1
jupyterlab>4.0,<4.1; platform_system == "Linux"
requests [security] >= 2.8.1, == 2.8.* ; python_version < "2.7"
Install dependencies
  • pip
    pip install -r requirements.txt
  • pipenv
    pipenv install -r requirements.txt
Deactivate the active environment
deactivate
Structure of a Python project
A Python library (=> made to be imported) consists of:
  • Python files with the extension .py made for import, called modules,
  • directories containing Python files, called packages.
A Python project (=> made to be distributed and installed) can have different layout:
  • single module
  • flat
  • src
Single module
examples/calculator_mod/
├── calculator_mod.py
├── pyproject.toml
├── README.md
└── LICENSE.txt
Flat layout
examples/calculator_flat_layout/
├── calculator
│   ├──__init__.py
│   └── operator
│       ├── __init__.py
│       ├── add.py
│       └── sub.py
├── pyproject.toml
├── README.md
└── LICENSE.txt
Src layout
examples/calculator_src_layout/
├── src
│   └── calculator
│       ├──__init__.py
│       └── operator
│           ├── __init__.py
│           ├── add.py
│           └── sub.py
├── pyproject.toml
├── README.md
└── LICENSE.txt
=> requires to (editable) install
pip install -e .
pip install .
Packaging and distributing
Most important files:
  • pyproject.toml (configuration file)
  • README (.rst or .md)
  • LICENSE
Configuration
minimum required:
[build-system]
requires = ["setuptools"]
build-backend = "setuptools.build_meta"
[project]
name = "calculator"
dynamic = ["version"]
requires-python = ">=3.8"
[tool.setuptools.dynamic]
version = { attr = "calculator.version.__version__" }
Others backends: Hatchling, PDM, Flit, Whey, Scikit-build, etc.
You can add the dependencies of your project:
[project]
dependencies = [
  "numpy",
You can add a command line interface to transform your library to an application:
[project.scripts]
calculator-script = "calculator.command_line:main"
To distribute and to be more visible, you need to fill in a little more information before distributing. For example:
  • description
  • authors/ maintainers
  • readme
  • license
  • keywords
  • classifiers
Package your project
Use build package to do the packaging. It builds the package in an isolated environment, generating a source-distribution and wheel in the directory dist/.
python -m build
python -m build -s # only source (sdist)
python -m build -w # only wheel (bdist)
  • sdist is an archive .tar.gz that contains your source files.
    pip use it to build the wheel when it doesn't find a corresponding wheel.
  • bdist creates a wheel format containing files and metadata that only need to be moved to the correct location on the target system, to be installed.
    • pure python => not platform dependant (hello-0.1-py3-none-any.whl) and contains your python files.
    • not pure python => platform dependant (calculator-0.1.0-cp310-cp310-linux_x86_64.whl). It contains python files and compiled files (.so, .dll, ...)
Publish your package
The twine tool lets you put the distributions you've created in the dist directory on PyPI. Two sites are available:
Documentation
For writing Python application documentation, sphinx is widely used now.
It can be configured with the file conf.py. It can be extended with extensions like autodoc to read automatically the documentation from the docstrings.
To start your documentation run
sphinx-quickstart docs
and answer questions. It will generate the basic files needed by sphinx.
Build your documentation
To build the documentation, you can run
sphinx-build -M html sourcedir outputdir
or
make html # if you ran sphinx-quickstart before
You can see your documentation by opening the index.html file located inside your build folder.
Add contents
In Sphinx source files, you can use most features of standard reStructuredText (.rst).
The index.rst file will be your landing page.
You can then add a new page by creating a new .rst file.
For example api.rst:
.. function:: foo(x)
              foo(y, z)
   :module: some.module.name
   Return a line of text input from the user.
Now you can link your page in the toctree of index.rst
.. toctree::
   :maxdepth: 2
   :caption: Contents:
   api
Theme
The default theme is Alabaster. You can change it by setting the variable html_theme in the conf.py file
html_theme = 'pydata_sphinx_theme'
Other themes:
  • sphinx_rtd_theme
  • pydata_sphinx_theme
  • furo
See more themes here: https://sphinx-themes.org/
Extensions
To add an extension you need to add your extension inside the variable
extensions in the conf.py file.
For example:
extensions = [..., "sphinx.ext.autodoc", ...]
List of nice extensions
  • sphinx.ext.autodoc
  • sphinx.ext.viewcode
  • sphinx.ext.napoleon
  • sphinx-copybutton
  • nbsphinx
  • nbsphinx-link
  • myst-parser
Continuous Deployment
Package distribution
GitHub
  • create an environment (ex pypi) to deploy.
  • create a workflow that triggers on release
    • use github actions to build and publish (pypi-publish) the package
  • on PyPI add your workflow as a trusted publisher
  • do a release from github
GitLab
There is neither github action nor trusted publisher so we need to use
twine with a api token to publish.
  • on PyPI create an api token
  • save it to your environment variable or project variable.
  • create a pipeline that triggers on tag
    • create jobs that build and publish with your token (saved in a CI/CD variable)
  • do a release or push a git tag
Documentation distribution
  • readthedoc
    • requirements.txt
    • .readthedocs.yml
  • pages
    • GitHub with github actions
    • GitLab with the pages job
Pratical session
Go to https://gitlab.inria.fr/tutos-technos/python-pip-code-distribution/-/wikis/home.
Don't hesitate to look at some project examples located in the examples folder
Do the exercises of the wiki:
  • env, structure (30 min)
  • packaging and distributing (~1h)
  • documentation (~30 min)
  • CD (~30min)
You can always ask questions !!!
